"Search for a phrase in multiples PDFs via a list of URLs"
User: "carl"
New Altair Community Member
Updated by Jocelyn
Is it possible to input a list of URLs (which contain PDFs), then search for a phrase in all the PDFs, and return a table with the URL path and the searched-for text?  I'd like to do this without downloading all the PDFs.
This is what I have so far, which runs, but doesn't create an attribute.
1 - Read Excel (with URLs)
2 - Loop Examples
2a - Extract Macro
2b - Open File
2c - Read Document
2d - Extract Information
3 - Select Attributes
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="7.3.000" expanded="true" height="68" name="Read Excel" width="90" x="179" y="34">
<parameter key="excel_file" value="/Users/carl/Documents/SD PDFs.xlsx"/>
<parameter key="imported_cell_range" value="A"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="locale" value="English (United Kingdom)"/>
<parameter key="0" value="SvceDef Link.true.file_path.attribute"/>
</list>
<operator activated="true" class="loop_examples" compatibility="7.3.000" expanded="true" height="103" name="Loop Examples" width="90" x="313" y="34">
<operator activated="true" class="extract_macro" compatibility="7.3.000" expanded="true" height="68" name="Extract Macro" width="90" x="45" y="34">
<parameter key="macro" value="GetURL"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="SvceDef Link"/>
<parameter key="example_index" value="%{example}"/>
<list key="additional_macros"/>
<operator activated="true" class="open_file" compatibility="7.3.000" expanded="true" height="68" name="Open File" width="90" x="179" y="34">
<parameter key="resource_type" value="URL"/>
<parameter key="url" value="%{GetURL}"/>
<operator activated="true" class="text:read_document" compatibility="7.3.000" expanded="true" height="68" name="Read Document" width="90" x="313" y="34">
<parameter key="content_type" value="pdf"/>
<operator activated="true" class="text:extract_information" compatibility="7.3.000" expanded="true" height="68" name="Extract Information" width="90" x="447" y="34">
<parameter key="query_type" value="Regular Expression"/>
<list key="string_machting_queries"/>
<list key="regular_expression_queries">
<parameter key="Text" value="sample text"/>
</list>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Open File" from_port="file" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_op="Extract Information" to_port="document"/>
<connect from_op="Extract Information" from_port="document" to_port="output 1"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="select_attributes" compatibility="7.3.000" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="34">
<parameter key="attribute" value="Text"/>
<connect from_op="Read Excel" from_port="output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="example set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
