Hello everyone,
i'm trying to perform sentiment analysis to a bunch of data and i want to test different parameters of Process Document from Data operator.It is obvious that i can't test manually all the possible combinations of prune methods or token filtering (within Process Documents operator) . Is there any way to loop this procedure in order to find the optimum values of the parameters?
Thank you
