Cut the document in equal pieces
How can I cut the documents in equal parts (e.g. 10 parts) and save them as separate documents. I cannot use regex (an so the cut doc operator), since I have several documents of different format. I tried the window-operator, but I do not quiet understand how to use it. Thank you in advance for any help!
Best Answer
Hi ln777,
the window documents operator should do the job. You might need to extract the number of tokens for every document. For an example, please have a look at the attached process.
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.000">
<context>
<input/>
<output/>
<macros>
<macro>
<key>window_length</key>
<value>5</value>
</macro>
</macros>
</context>
<operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:create_document" compatibility="7.2.001" expanded="true" height="68" name="Create Document" width="90" x="112" y="34">
<parameter key="text" value="Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet."/>
<operator activated="true" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Tokenize" width="90" x="313" y="34"/>
<operator activated="false" class="text:process_documents" compatibility="7.2.001" expanded="true" height="82" name="Process Documents" width="90" x="380" y="238">
<operator activated="false" class="text:window_document" compatibility="7.2.001" expanded="true" height="68" name="Window Document" width="90" x="112" y="34">
<parameter key="step_size" value="10"/>
<portSpacing port="source_segment" spacing="0"/>
</process>
<connect from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="text:aggregate_token_length" compatibility="7.2.001" expanded="true" height="68" name="Aggregate Token Length" width="90" x="447" y="34">
<parameter key="aggregation" value="count"/>
<operator activated="true" breakpoints="after" class="subprocess" compatibility="7.3.000" expanded="true" height="103" name="Subprocess" width="90" x="581" y="34">
<operator activated="true" class="multiply" compatibility="7.3.000" expanded="true" height="103" name="Multiply" width="90" x="45" y="34"/>
<operator activated="true" class="text:documents_to_data" compatibility="7.2.001" expanded="true" height="82" name="Documents to Data" width="90" x="179" y="85">
<parameter key="text_attribute" value="text"/>
<operator activated="true" class="extract_macro" compatibility="7.3.000" expanded="true" height="68" name="Extract Macro" width="90" x="313" y="187">
<parameter key="macro" value="number_of_tokens"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="token_length"/>
<parameter key="example_index" value="1"/>
<list key="additional_macros"/>
<operator activated="true" class="generate_macro" compatibility="7.3.000" expanded="true" height="82" name="Generate Macro" width="90" x="447" y="187">
<parameter key="window_length" value="replace(str(eval(%{number_of_tokens})/10),".0","")"/>
</list>
<connect from_port="in 1" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_port="out 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="Documents to Data" to_port="documents 1"/>
<connect from_op="Documents to Data" from_port="example set" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_port="out 2"/>
<portSpacing port="source_in 2" spacing="0"/>
<portSpacing port="sink_out 3" spacing="0"/>
</process>
<operator activated="true" class="text:window_document" compatibility="7.2.001" expanded="true" height="68" name="Window Document (2)" width="90" x="782" y="34">
<parameter key="window_length" value="%{window_length}"/>
<parameter key="step_size" value="%{window_length}"/>
<connect from_port="segment" to_port="document 1"/>
</process>
<connect from_op="Create Document" from_port="output" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Aggregate Token Length" to_port="document"/>
<connect from_op="Aggregate Token Length" from_port="document" to_op="Subprocess" to_port="in 1"/>
<connect from_op="Subprocess" from_port="out 1" to_op="Window Document (2)" to_port="document"/>
<connect from_op="Window Document (2)" from_port="documents" to_port="result 1"/>
</process>
</process>0
Hi ln777,
Best,
Martin
<context>
<input/>
<output/>
<macros>
<macro>
<value>5</value>
</macro>
</macros>
</context>
</process>
</process>
</list>
</process>
</process>
</process>
</process>0 -
Thank you for the process. It works nicely!
0 -
I have also follow-up question to the process. If I put this process into the loop files, how can I write all parts as separate txt.documents to one directory?
0 -
the trick is the Loop Collection operator to loop over seperate windows. A handy thing is to use the macro %{a} to store it with a the execution_count as a postfix.
~Martin
0 -
Hi Martin,
I used loop collection and macro as you suggested, but still my process does not work. I cannot figure out why. Could you help?
<context>
<input/>
<output/>
<macros>
<macro>
<value>5</value>
</macro>
</macros>
</context>
<operator activated="true" class="loop_files" compatibility="7.3.000" expanded="true" height="82" name="Loop Files" width="90" x="313" y="85">
<parameter key="directory" value="D:\Reports"/>
<operator activated="true" class="text:read_document" compatibility="7.3.000" expanded="true" height="68" name="Read Document" width="90" x="45" y="85">
<parameter key="file" value="D:\Reports_txt\A2A_2008_SR.txt"/>
<operator activated="true" class="text:tokenize" compatibility="7.3.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="85"/>
<operator activated="true" class="text:aggregate_token_length" compatibility="7.3.000" expanded="true" height="68" name="Aggregate Token Length" width="90" x="313" y="85">
<operator activated="true" class="subprocess" compatibility="7.3.000" expanded="true" height="103" name="Subprocess" width="90" x="447" y="85">
<operator activated="true" class="text:documents_to_data" compatibility="7.3.000" expanded="true" height="82" name="Documents to Data" width="90" x="179" y="85">
</list>
</process>
<operator activated="true" class="text:window_document" compatibility="7.3.000" expanded="true" height="68" name="Window Document (2)" width="90" x="514" y="238">
</process>
<operator activated="true" class="loop_collection" compatibility="7.3.000" expanded="true" height="82" name="Loop Collection" width="90" x="648" y="238">
<operator activated="true" class="set_macro" compatibility="7.3.000" expanded="true" height="82" name="Set Macro (2)" width="90" x="313" y="34">
<parameter key="macro" value="filenumber"/>
<parameter key="value" value="0"/>
<operator activated="true" class="generate_macro" compatibility="6.0.002" expanded="true" height="82" name="Generate Macro (2)" width="90" x="447" y="34">
<parameter key="filenumber" value="%{filenumber}+1"/>
</list>
<operator activated="true" class="text:write_document" compatibility="7.3.000" expanded="true" height="82" name="Write Document" width="90" x="581" y="34">
<parameter key="file" value="D:\Reports_parts_txt\%{file_name}_%{filenumber}.txt"/>
<connect from_port="single" to_op="Set Macro (2)" to_port="through 1"/>
<connect from_op="Set Macro (2)" from_port="through 1" to_op="Generate Macro (2)" to_port="through 1"/>
<connect from_op="Generate Macro (2)" from_port="through 1" to_op="Write Document" to_port="document"/>
<connect from_op="Write Document" from_port="document" to_port="output 1"/>
<portSpacing port="source_single" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_port="file object" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_op="Tokenize" to_port="document"/>
<connect from_op="Window Document (2)" from_port="documents" to_op="Loop Collection" to_port="collection"/>
<connect from_op="Loop Collection" from_port="output 1" to_port="out 1"/>
<portSpacing port="source_file object" spacing="0"/>
</process>
<connect from_op="Loop Files" from_port="out 1" to_port="result 1"/>
</process>
</process>0 -
Hi ln777,
i think the attached process should work.. Not tested it though.
~Martin
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.002">
<context>
<input/>
<output/>
<macros>
<macro>
<value>5</value>
</macro>
</macros>
</context>
<operator activated="true" class="process" compatibility="7.2.002" expanded="true" name="Process">
<operator activated="true" class="loop_files" compatibility="7.2.002" expanded="true" height="82" name="Loop Files" width="90" x="112" y="34">
<operator activated="true" class="text:read_document" compatibility="7.2.000" expanded="true" height="68" name="Read Document" width="90" x="45" y="85">
<operator activated="true" class="text:tokenize" compatibility="7.2.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="85"/>
<operator activated="true" class="text:aggregate_token_length" compatibility="7.2.000" expanded="true" height="68" name="Aggregate Token Length" width="90" x="313" y="85">
<operator activated="true" class="subprocess" compatibility="7.2.002" expanded="true" height="103" name="Subprocess" width="90" x="447" y="85">
<operator activated="true" class="multiply" compatibility="7.2.002" expanded="true" height="103" name="Multiply" width="90" x="45" y="34"/>
<operator activated="true" class="text:documents_to_data" compatibility="7.2.000" expanded="true" height="82" name="Documents to Data" width="90" x="179" y="85">
<operator activated="true" class="extract_macro" compatibility="7.2.002" expanded="true" height="68" name="Extract Macro" width="90" x="313" y="187">
<operator activated="true" class="generate_macro" compatibility="7.2.002" expanded="true" height="82" name="Generate Macro" width="90" x="447" y="187">
</list>
</process>
<operator activated="true" class="text:window_document" compatibility="7.2.000" expanded="true" height="68" name="Window Document (2)" width="90" x="514" y="238">
</process>
<operator activated="true" class="loop_collection" compatibility="7.2.002" expanded="true" height="82" name="Loop Collection" width="90" x="648" y="238">
<operator activated="false" class="set_macro" compatibility="7.2.002" expanded="true" height="68" name="Set Macro (2)" width="90" x="313" y="34">
<operator activated="false" class="generate_macro" compatibility="6.0.002" expanded="true" height="68" name="Generate Macro (2)" width="90" x="447" y="34">
</list>
<operator activated="true" class="text:write_document" compatibility="7.2.000" expanded="true" height="82" name="Write Document" width="90" x="581" y="34">
<parameter key="file" value="D:\Reports_parts_txt\%{file_name}_%{a}.txt"/>
<connect from_port="single" to_op="Write Document" to_port="document"/>
</process>
</process>
</process>
</process>0 -
As always, thank you for the quick help. Unfortunately the process does not work correctly. By "Extract macro" operator I get an error message "The attribute "token length" is missing in the input example set. Besides, by the "window document"-operator I get an error message "Supply value for step size". Do you have any ideas how to fix it?
0 -
this sounds odd, because the attached process which is pretty similar except for the loop files works well. Are you sure that your loop has only parsable files in?
~Martin
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
<context>
<input/>
<output/>
<macros>
<macro>
<value>5</value>
</macro>
</macros>
</context>
<operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
<operator activated="false" class="loop_files" compatibility="7.3.001" expanded="true" height="68" name="Loop Files" width="90" x="45" y="391">
<operator activated="false" class="text:read_document" compatibility="7.3.000" expanded="true" height="68" name="Read Document" width="90" x="246" y="340">
</process>
<operator activated="true" class="text:create_document" compatibility="7.3.000" expanded="true" height="68" name="Create Document" width="90" x="45" y="85">
<operator activated="true" class="text:write_document" compatibility="7.3.000" expanded="true" height="82" name="Write Document (2)" width="90" x="45" y="238">
<parameter key="file" value="C:\Users\Martin\LoremIpsum.txt"/>
<operator activated="false" class="loop_collection" compatibility="7.3.001" expanded="true" height="82" name="Loop Collection" width="90" x="782" y="85">
<operator activated="false" class="set_macro" compatibility="7.3.001" expanded="true" height="68" name="Set Macro (2)" width="90" x="313" y="34">
</list>
</process>
<operator activated="true" breakpoints="before" class="text:read_document" compatibility="7.3.000" expanded="true" height="68" name="Read Document (2)" width="90" x="179" y="238">
<operator activated="true" class="subprocess" compatibility="7.3.001" expanded="true" height="103" name="Subprocess" width="90" x="447" y="85">
<operator activated="true" class="multiply" compatibility="7.3.001" expanded="true" height="103" name="Multiply" width="90" x="45" y="34"/>
<operator activated="true" class="extract_macro" compatibility="7.3.001" expanded="true" height="68" name="Extract Macro" width="90" x="313" y="187">
<operator activated="true" class="generate_macro" compatibility="7.3.001" expanded="true" height="82" name="Generate Macro" width="90" x="447" y="187">
</list>
</process>
<operator activated="true" class="text:window_document" compatibility="7.3.000" expanded="true" height="68" name="Window Document (2)" width="90" x="648" y="85">
</process>
<connect from_op="Create Document" from_port="output" to_op="Write Document (2)" to_port="document"/>
<connect from_op="Read Document (2)" from_port="output" to_op="Tokenize" to_port="document"/>
</process>
</process>0 -
Hi Martin,
I still cannot fix the problem with cutting the documents. I tried to create a txt-file with a simple text ("My name is Mary") using the last process you posted here. I got the same error as I before. However, if I use the LoremIpsum.txt the process works fine. I cannot understand why. Maybe you have any solution?
