Import Configuration Wizard Question
User: "Ike3000"
New Altair Community Member
Updated by Jocelyn
I use the Read Excel Operator with the Import Config Wizard. Is there a chance to save the import Settings, so that once I leave the Import Config Wizard and click on it again, the previous settings will reappear when I navigate through the 4 Steps of the Import Confi Wizard?
I really like the idea of the Import Config Wizard, but sometimes I need to readjust one of the Import Settings. Once I leave the Import Congig Wizard, I have to start all over again, instead of just making a slight adjustment. Also, when I use the Import Config Wizard to set specific roles (Instead of using "Set Role" Operator) or to preselect attributes (instead of using "Select Attributes" Operator), these settings will be gone, once I click on the Wizard again.
It's also bad in terms of reproducibility . When I share a chain of processes that uses the Import Config Wizard for preselecting attributes or setting roles, another person won't be able to see which preselection and roles I have set within the Wizard.
1 - 1 of 11
    User: "Telcontar120"
    Accepted Answer
    Actually, all the information that you select in the wizard is captured in the parameters, which are saved in the operator, and they are accessible to anyone else that views the process later.  You can find them here (look at the attached screenshot) and you can adjust anything you need directly from this screen once you click on the "edit list" button such as the attribute name, data type, role without having to rerun the entire wizard.
