Hello.
Is there any way that I can read a 18-digit .Net system.datetime in Rapidminer? I like to convert it to something readable for a human.
Here is an examble of a number; 634019213109374850
Which should be converted to 2010-02-16T12:48:30.937Z
That is actually pretty tough. Originally I thought, that you can just convert the ticks into milliseconds and convert this into a date object (see process below). But the problem is that this does not account for DST, leap seconds etc. which means that in aggregate you are roughly 4 weeks off :smileysad:
I posted the process for educational reasons but this might not something you can easily solve without calling an external .Net routine (which is possible, e.g. with a command line call done by the operator "Execute Program").
Cheers,
Ingo
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="7.3.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="34"> <list key="attribute_values"> <parameter key="dot_net_date" value="634019213109374850"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_attributes" compatibility="7.3.000" expanded="true" height="82" name="Generate Attributes" width="90" x="246" y="34"> <list key="function_descriptions"> <parameter key="dot_net_date" value="(dot_net_date/10000)-(1970*365*24*60*60*1000)"/> </list> </operator> <operator activated="true" class="numerical_to_date" compatibility="7.3.000" expanded="true" height="82" name="Numerical to Date" width="90" x="380" y="34"> <parameter key="attribute_name" value="dot_net_date"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Numerical to Date" to_port="example set input"/> <connect from_op="Numerical to Date" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
