Edit SQL query
Hey everyone,
I am new to Rapidminer (started today) and I was able to create a connection to the db, ran a query and created a process to export to csv - excellent.
However, I want to change the date range in the where clause, but I cannot figure out how to do that. I am using the latest Mac desktop version
The closest thing that I have found was to click on "Add Data," create and overwrite the same data storage with the same name, but I will not always have the SQL query in the clipboard for future references. How can I modify/edit the original SQL query used to create the result set
Thanks in advance
Best Answer
Hello!
If you use a Read Database operator you can provide a SQL statement with your WHERE statement included. That should solve the problem.
Best,
Martin
2
Hello!
Best,
Martin
2 -
Thank you @mschmitz, that worked. Now how do I mark a question as solved?
