I installed the Execute R script operator in RapidMIner. Everything works fine but I found the following code didn't work:
rm_main = function(dataset)
new_dataset = dataset[1,c(1,5)]
return new_dataset
Basically all the operations using "[]" doesn't work properly. I understand this can be done by Select Attributes in RapidMIner, but is it my problem or such R syntax is not supported in RapidMIner?
