Java could not be launched. Probably there is not enough free memory available. ....
User: "sabahsuhail_nus"
New Altair Community Member
Updated by Jocelyn
Hi I am facing this error :
Java could not be launched. Probably there is not enough free memory available. Please close all other applications and try again. Errorcode: 1
I install rapidminer studio on windows 7 (64bit) and when i open RM it gives me this error. Please help me to solve it
1 - 7 of 71
    User: "zprekopcsak"
    How much memory do you have in that Win7 machine? Please note that minimum requirement is 4GB and we recommend 16GB:  http://docs.rapidminer.com/studio/installation/system-requirements.html
    Best, Zoltan
    User: "mmichel"
    This is a generic error message which will be displayed if the virtual machine could not be started. You should also try to start RapidMiner Studio via the .bat file and check if there is any detailed error message available.
    User: "Ivan_Ingrian"
    I am getting the same error. I have 8gb RAM on my laptop. Just installed latest version of Java (8 upd 121) and it is working correctly everywhere except RapidMiner
    User: "mmichel"
    Have you tried to start Studio via the .bat or .sh file? What error message/exception do you get in the command window?
    User: "momoustafa"
    I'm getting the same error when launching Rapidminer fro mthe exe file.
    when i tried the batch file it gave me another error (screenshot below)
    User: "mmichel"
    Hi momoustafa,
    two ideas:
    • If H is a network device please try to install RapidMiner Studio on a local drive instead
    • Check your firewall settings, make sure RM Studio is not blocked
    Cheers,
    Marcel
    User: "Paola"
    Hi, same problem as above with Academic Licence.
    Checked Firewall already and added RM Studio
    My setup is as follows:
    Version:1.0 StartHTML:000000235 EndHTML:000018368 StartFragment:000017776 EndFragment:000018312 StartSelection:000017784 EndSelection:000018302 SourceURL:https://docs.rapidminer.com/studio/installation/system-requirements.htmlSystem Requirements - RapidMiner Documentation
    • Dual core
    • 2GHz processor
    • 16GB RAM (~ 20% in use)
    • >100GB free disk space
    Operating System
    • 64-bit
    • Windows 10 Pro
    Java platform
    • 64-bit
    • Java 8.141
    Any additional advice?
