"Rwordseg in Execute R"
I am trying to use Rwordseg in Chinese text mining. But it shows "Process failed. Script terminated abnormally."
The R script I put to execute is as follow, hope someone can help me to solve this problem, thanks.
rm_main = function(data)
library(Rwordseg)
data2<-as.data.table(segmentCN(data$Sentence))
return(data2)
Any other errorlog or tips?
I try to use your code to run a bit, it is normal.
Maybe you can describe your input dataset example?1 -
I use Read Excel operator. The excel file, which includes chinese words example, is imported through Import Configuration Wizard. The message from RapidMiner is in the following, thanks for your help.
Message: Script terminated abnormally.
Exception: com.rapidminer.operator.OperatorExceptionStack trace:
com.rapidminer.operator.scripting.AbstractScriptRunner.run(AbstractScriptRunner.java:162)
com.rapidminer.operator.scripting.AbstractScriptingLanguageOperator.doWork(AbstractScriptingLanguageOperator.java:90)
com.rapidminer.operator.scripting.r.RScriptingOperator.doWork(RScriptingOperator.java:73)
com.rapidminer.operator.Operator.execute(Operator.java:1002)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:76)
com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:811)
com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:806)
java.security.AccessController.doPrivileged(Native Method)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:806)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:392)
com.rapidminer.Process.run(Process.java:1195)
com.rapidminer.Process.run(Process.java:1091)
com.rapidminer.Process.run(Process.java:1044)
com.rapidminer.Process.run(Process.java:1039)
com.rapidminer.Process.run(Process.java:1029)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
0 -
Have you checked your encoding? Sometimes this can be an encoding issue from Excel which is piped through the process to the R Script.
1
