how to export models?
User: "juju"
New Altair Community Member
Updated by Jocelyn
Hi, I would like to export models in RM, and later see in other softwares. Is there a way to do it?
So the basic thing I'm thinking of is to export the text/table part in the model, a further thing is to save the tree strucutre in a tree model.
Thanks-
Trivial sample code (for exmale these two models)
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
<parameter key="target_function" value="polynomial classification"/>
<operator activated="true" class="multiply" compatibility="6.4.000" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="6.4.000" expanded="true" height="76" name="SVM" width="90" x="380" y="30">
<list key="class_weights"/>
<operator activated="true" class="parallel_decision_tree" compatibility="6.4.000" expanded="true" height="76" name="Decision Tree" width="90" x="380" y="165"/>
<connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="SVM" to_port="training set"/>
<connect from_op="Multiply" from_port="output 2" to_op="Decision Tree" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="result 1"/>
<connect from_op="Decision Tree" from_port="model" to_port="result 2"/>
</process>
</process>
