lower case without removing numbers
m_meijsUser: "m_meijs"
New Altair Community Member
Updated by Jocelyn
Hi all,
I am trying to join two tables together. Because they are both open fields, there are some differences in names regarding punctuation, use of capitals etc.
I have now transformed the variables to match on like this to overcome this problem: replaceAll(lower(trim(VARIABLE)), "[. ,()-:?]","").
However, this code also deletes all numbers in the variable name and I don't want that.
Any thoughts?
1 - 1 of 11
    Thomas_OttUser: "Thomas_Ott"
    Accepted Answer
    If these are nominal values, then I would definately use the Replace operator and do the regex first to remove the puncuation AND then do the lowering/trimming.
    Just doing a regex with \W selects all the puncuation and then replace with either a "_" or nothing will get rid of the puncutation. If that's not the desired effect then I would consider splitting off the numbers, doing the lower/trim, and then rejoin the numbers.
