In order to calculate a score, I need the alpha column in the Support Vector Table of the One-Class SVM model. For information, the model was calculated using the LibSVM bloc. Is there a way to extract the example set corresponding to this table ? The idea is to extract this information automatically. I would like to avoid doing it manually.
Kind regards,
