I wish to use the Optimise Selection (evolutionary) operator. I have been using the example in the tutorial and cannot figure out how to see the predicted lable column in the example dataset so that I can plot predicted vs original label values.
You can try using a Remember and Recall operator. See attached
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Root"> <parameter key="random_seed" value="2000"/> <process expanded="true"> <operator activated="true" breakpoints="after" class="retrieve" compatibility="7.2.003" expanded="true" height="68" name="Polynomial" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Polynomial"/> </operator> <operator activated="true" class="optimize_selection_evolutionary" compatibility="7.2.003" expanded="true" height="103" name="Optimize Selection (Evolutionary)" width="90" x="313" y="30"> <parameter key="keep_best_individual" value="true"/> <process expanded="true"> <operator activated="true" class="split_validation" compatibility="7.2.003" expanded="true" height="124" name="Validation" width="90" x="246" y="187"> <process expanded="true"> <operator activated="true" class="support_vector_machine" compatibility="7.2.003" expanded="true" height="112" name="SVM" width="90" x="112" y="30"/> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="7.2.003" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="7.2.003" expanded="true" height="82" name="Apply Model (2)" width="90" x="447" y="34"> <list key="application_parameters"/> </operator> <operator activated="true" class="remember" compatibility="7.2.003" expanded="true" height="68" name="Remember" width="90" x="581" y="34"> <parameter key="name" value="PredvsActual"/> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Validation" from_port="training" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Validation" from_port="averagable 1" to_port="performance"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Remember" to_port="store"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_performance" spacing="36"/> </process> </operator> <operator activated="true" class="recall" compatibility="7.2.003" expanded="true" height="68" name="Recall" width="90" x="514" y="136"> <parameter key="name" value="PredvsActual"/> </operator> <connect from_op="Polynomial" from_port="output" to_op="Optimize Selection (Evolutionary)" to_port="example set in"/> <connect from_op="Optimize Selection (Evolutionary)" from_port="example set out" to_port="result 1"/> <connect from_op="Optimize Selection (Evolutionary)" from_port="performance" to_port="result 2"/> <connect from_op="Recall" from_port="result" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="18"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
