I am trying to export xml for a process and I believe that I need to click on view>show panel>xml, however the view>show panel menu ends at Result History, and does not scroll further. How do I fix this?
depends on what extensions you have installed. The list cycles back to the top when continuing to press the down arrow key. So you can count how many items there are.
Marco
until this gets fixed, you can use the following workaround to activate "hidden" panels:
Hover with the mouse over an element in the menu and then use the "arrow down" key to navigate the menu. Press spacebar when you think you might have the correct panel selected.
and how many items are their on the show panel menu? I do not know as I have never seen the whole menu
thanks
I got the same problem with the latest 8.0.001 - can't see anything after Repository in the show panel list. Could anyone tell me how many items down from Repositry is XML? Thank you in advance.
hello @yy7777 - welcome to the community. Unfortunately it's alphabetical so XML is usually last.
Scott
thanks. Hope the problem can be fixed soon.
