hi,
I can#t set the correct repository path in store and export process parameter field...
I want to use time macro to create a folder and save them (example set + process) in the same folder ... here is my process:
when I set the store path to "%{Zeit}/NameofExampleSet" it says invalid character "/"
but I can do the same in the export process operator, there it works:
%{Zeit}/Prozess
