Hi all,
I'm currently building my own credit risk model in RM and I have an issue after one of the steps. Without going to much into detail about the model itself, here a the steps leading to my issue:
1) Bin numeric attributes
2) Obtain number of defaults and non-defaults in each bin
3) Make certain calculations
My current outcome is a table looking like this:
| Attribute 1 |
Defaults |
NonDefaults |
DefaultPercentage |
NonDefaultPercentage |
DefaultRate |
WOE |
IV |
| range1 [-∞ - 0.149] |
19,0 |
29,0 |
,2 |
,1 |
,7 |
-,7 |
,1 |
| range2 [0.149 - 0.304] |
19,0 |
30,0 |
,2 |
,1 |
,6 |
-,6 |
,1 |
| range3 [0.304 - 0.453] |
13,0 |
36,0 |
,1 |
,1 |
,4 |
-,1 |
,0 |
| range4 [0.453 - 0.680] |
14,0 |
35,0 |
,1 |
,1 |
,4 |
-,2 |
,0 |
But this is only for 1 attribute, while I need to do this for at least 10-15 attributes. What I specifically need is the above output, but with an extra column on the left where the attribute is named next to the bin, and with all the attributes below each other. Thus, for the above example, it would result in:
| Attributes |
Bins |
Defaults |
NonDefaults |
DefaultPercentage |
DefaultRate |
WOE |
IV |
| Attribute 1 |
19,0 |
29,0 |
,2 |
,1 |
,7 |
-,7 |
,1 |
| Attribute 1 |
19,0 |
30,0 |
,2 |
,1 |
,6 |
-,6 |
,1 |
| Attribute 1 |
13,0 |
36,0 |
,1 |
,1 |
,4 |
-,1 |
,0 |
| Attribute 1 |
14,0 |
35,0 |
,1 |
,1 |
,4 |
-,2 |
,0 |
| Attribute 2 |
range1 [-∞ - 0.011] |
9,0 |
39,0 |
,1 |
,1 |
,2 |
,4 |
,0 |
| Attribute 2 |
range2 [0.011 - 0,024] |
6,0 |
43,0 |
,1 |
,1 |
,1 |
,9 |
,1 |
| Attribute 2 |
range3 [0.024 - 0.037] |
5,0 |
44,0 |
,1 |
,2 |
,1 |
1,1 |
,1 |
| Attribute 2 |
range4 [0,037 - ∞] |
8,0 |
41,0 |
,1 |
,1 |
,2 |
,5 |
,0 |
And so on for al the attributes. Now I have to perform and hard code al the attributes seperately, which is not very efficient.
I already tried the loop attributes operator, but I don't seem to get it working.
I used the standard credit risk model data set available in RapidMiner. If I need to add more detail regarding the process itself, just ask!
Any thoughts?
