Splitting output into multiple (many) csv
User: "MichaelWall"
New Altair Community Member
Updated by Jocelyn
Hi
Question from a newbee. I have a process built in RapidMiner studio that creates an output containing anywhere between 100 and 5000 rows (depending on starting input). I want to write out the output as one csv per row. At the moment I can get the full data set using the Write CSV operator, but that just gives me one file with everything, when I want 1 csv per record. I've tried doing this in post-processing by adding a new section to the Python script that handles the data after it's been through the process, but the formatting of the CSV is causing problems. I really want it to come out of RapidMiner in separate files to maintain the integrity of the results.
Any thoughts appreciated?
Thanks
1 - 1 of 11
    User: "bhupendra_patil"
    Accepted Answer
    Hi @MichaelWall
    Welcome to RapidMiner community.
    See if the attached process helps you. You can open this process from FIle>>Import Process
    You may need to change path of the csv location
    But here is what it does
    I am going to loop examples(rows), basically one row at a time,
    Inside the loop you filter to current row number and then write that one row to one csv
    the filename is the rownumber.csv
    If you need to name the file differenty, then that should be possible with additonal operator, but hopefully this will get you started
