Hello Everyone,
I am running a process that needs to use 2 De-pivot operators. The dataset is large (aprox 900k examples). The first De-pivot runs fine but the second one crashes out of memory, even though I have a machine with 16GB of RAM.
I know there should be some workaround by using the Loop Batches (inserting inside the second de-pivot) and Append operators, but I just can't get it to work. Could you please explain me how to exactly set these operators to work?
Thanks a lot for your help,
Best,
