Hi...I find often that some pop-up windows that require an "OK" or "Cancel" option vary. Some I have to physically click "OK" with the mouse (i.e. the return key on the keyboard does nothing), and other times the return key works. Adding rows in the Data Editor is a good example (see screenshot). It is much faster to hit the return key than mousing over to the OK button all the time. Thank you!
