I closed repository by mistake, so I do not know how to import data now. Do you have any ideas to open repository again?
simply go to view and either add via Show Panel or use Restore Default View:
Hi!
Thanks for your reply, but I can not find view on the top of my rapidminer, what is the matter?
my teacher told me same way before, but I can not find view on my rapidminer, what is the matter with that, my version is mac7.22
you are on a mac right? Thus the menu is in most upper status bar.
~Martin
Hey,
If you're worried that things are broken with your view there is a technical reset the can be done -
Inside of your .Rapidminer directory you will find gui.properties and vlperspective-predefined-design.xml - appending these files to .old and restarting Rapidminer Studio will allow Rapidminer to rebuild itself to the default view and gui settings - any changes that may have been made in error to your rapidminer settings would be removed.
