Good day,
I'm new to Rapid Miner and predictive analytics. I'm trying to move beyond the tutorials (which are great!) by using the US baby names (state-by-state) found on Kaggle. I'm able to load a random sample (1000 records) of the state-by-state data in:
- id (ID type)
- name (nominal type)
- gender (binominal type)
- state (nominal type)
- year (integer type)
- count (weight type)
Then I use another random selection to get 20 records without the state attribute. I'd like make a prediction of birth state based on name, gender, and birth year. I'm sure this is a contrived example, but I thought I'd give it a try. Alternatively, I'd like to predict birth year given name, gender, and state. What would be some interesting models to try in this case?
I've tried using Decision Tree to generate a model from the training data and Apply Model to the random Test Data. As best I can tell, Decision Tree is only working on year and gender, ignoring name. Is there anyway to get this model to consider name? Perhaps the issue is that I can't train on more than 1000 records due to licensing?
Process so far...
Decision tree on year, then sometime gender.
Thanks in advance,
Guy
