How will the client view the project that we develop in RapidMiner? What would be the client interface ?
the QVX operator is part of an extension. You need to install the Qlik extension in order to have it. Have a look at this article: http://docs.rapidminer.com/studio/installation/adding-extensions.html to see how you can add extensions.
~Martin
Hi aishwarya_shett,
there are quite a few options you can go. Most of them involve RapidMiner Server:
Thank you so much Martin. The other thing that I wanted to ask is I have noticed in one of the videos I came accross this operator called 'Write QVX' under the Qlik connections subfolder in the operator panel. This video was with the one using RapidMiner studio version 6.2. I am using version 7.2 and I didn't find any such operator.
Regards
Thanks a lot
