"generate a sublist from the weight object based on the weight value"
User: "winecoding"
New Altair Community Member
Updated by Jocelyn
I applied 'weight by information gain" for the feature selection. The generated weight object is a two column attribute. Assume the whole weight list has 2000 elements. The following figure is just a screen shot. Is that possible for me to select the top 50 elements based on the weight? For instance, I only want to generate a attribute list with 50 elements which are ranked as top 50 in the original weight object.
Comments
No comments on this post.
