hi,
Is it somehow possible to use operators for the LBP (Local Binary Pattern) Image detection of an image?
I recently read about LBP, and how useful it is for image classification (e.g for textures). Basically, each image is transformed into a grayscale image. Then for each pixel, the neighbourhood of pixel gray values is considered with respect to the center pixel. Then a threshold (bigger = 1, smaller = 0) is applied to pixel grayscale values. The 8 obtained values is transformed into 8 bit and then into decimal number. At the end, you obtain a histogram of counts of the decimal numbers that you obtian, which is characteristic for the image structure..
Is there any way to do this with rapidminer operators?
