Problem with Execute SQL Operator
New Altair Community Member
Updated by Jocelyn
Hi Community
I want to run some SQL Code with Execute SQL.
If I copy & past the code everything is working but if i read the code from file (attached as a csv, I saved codef in VisualStudio and saved the file as a .sql file) i get the following error:
Datbase error occured: Incorrect syntax near '>>' (see attached picture, i can't type it properly...)
Is this a problem with my file-encoding?
Cheers,
David
