hi,
I am trying since hours on a simple problem that drives me mad..
I compare 2 da tasets and want the dataset that is not in the other, I get it via the set minus operator, I have the ID attribute on both the same column, however, I get either non or all datasets in return... whats the problem?
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.2.001" expanded="true" height="68" name="Retrieve Z518B_0.75_RegionTable_AxioVision_ID_Faserlänge" width="90" x="45" y="238">
<parameter key="repository_entry" value="//RapidMiner_Nils/Nils/Master/Data/Einzellisten/Z518B_0.75_RegionTable_AxioVision_ID_Faserlänge"/>
<operator activated="true" class="rename_by_replacing" compatibility="7.2.001" expanded="true" height="82" name="Rename by Replacing" width="90" x="179" y="238">
<parameter key="attributes" value="F9::FeretMaximum !!R|F8::Faserlänge !!R|F6::EllipsekleineHalbachse !!R|F5::EllipsegroßeHalbachse !!R|F4::Durchmessergefüllt !!R|F3::Durchmesser !!R|F30::GrauwertMittelwert !!R|F29::GrauwertMinimum !!R|F28::GrauwertMaximum !!R|F27::Umfangkonvex !!R|F26::Umfanggefüllt !!R|F23::Umfang !!R|F22::Radius !!R|F21::MaximalereingeschriebenerKreis !!R|F20::IndexRegion!!I|F19::Formfaktor!!R|F17::FlächezuGesamtfläche !!R|F16::Flächekonvex !!R|F15::Flächegefüllt !!R|F14::Fläche !!R|F13::Feretverhältnis!!R|F11::FeretMinimum !!R"/>
<parameter key="replace_what" value=".*::(.*)!!.*"/>
<parameter key="replace_by" value="$1"/>
<operator activated="true" class="rename_by_replacing" compatibility="7.2.001" expanded="true" height="82" name="Rename by Replacing (2)" width="90" x="313" y="238">
<parameter key="replace_what" value=".*::(.*)\s.*"/>
<operator activated="true" class="set_role" compatibility="7.2.001" expanded="true" height="82" name="Set Role (2)" width="90" x="447" y="238">
<parameter key="attribute_name" value="Faserlänge "/>
<list key="set_additional_roles">
<parameter key="Faserlänge " value="id"/>
</list>
<operator activated="true" class="retrieve" compatibility="7.2.001" expanded="true" height="68" name="Retrieve Probe_MIT_LABEL_Z518B (2)" width="90" x="112" y="34">
<parameter key="repository_entry" value="//RapidMiner_Nils/Nils/Master/Data/Einzellisten/Probe_MIT_LABEL_Z518B"/>
<operator activated="true" class="set_minus" compatibility="7.2.001" expanded="true" height="82" name="Set Minus" width="90" x="715" y="340"/>
<connect from_op="Retrieve Z518B_0.75_RegionTable_AxioVision_ID_Faserlänge" from_port="output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_op="Rename by Replacing (2)" to_port="example set input"/>
<connect from_op="Rename by Replacing (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Set Minus" to_port="subtrahend"/>
<connect from_op="Retrieve Probe_MIT_LABEL_Z518B (2)" from_port="output" to_op="Set Minus" to_port="example set input"/>
<connect from_op="Set Minus" from_port="example set output" to_port="result 1"/>
</process>
</process>
