RapidMiner Server: memory management for repository access
User: "MariusHelf"
New Altair Community Member
Updated by Jocelyn
Hi all, hi Marco!
We were wondering how RapidMiner Server handles the reading and writing of big big objects from and to the Server Repository.
Say, we write an ExampleSet or a big model (e.g. a complex RandomForest model) of 2 GB to the Server repository. Does the Server cache the complete object in memory, or does it stream to the database? What when we read it back?
In other words: if the memory of the server is restricted to 2 GB, can we still reliably store bigger objects in the repository? (whether this is good practive is another question, but sometimes you have no choice...)
Also, does accessing the repository count against the api limit of the free RapidMiner Server, or does the api limit only apply to processes that are exposed as a webservice?
Cheers,
Marius
1 - 1 of 11
    User: "Marco_Boeck"
    Accepted Answer
    Hi Marius!
    Let me provide a few more details here:
    1. If you create the objects on RM Server itself, then at that point, they already have to be entirely in memory. Does not matter which type of object. So that naturally becomes tricky if they are larger than the maximum memory of RM Server.
    2. If you store an ExampleSet on Server via Studio or the REST API, it will be streamed. This means yes, you can upload larger sets than your memory limit.
    3. If you store a model (or any other IOObject really), it is stored as a binary blob. Thus it will be completely loaded into memory and as such problematic for objects larger than the memory limit.
    4. Indeed, only actual web services count against the limit. Neither does testing those count, nor does using the repository either via REST API or via Studio (SOAP API).
    Cheers,
    Marco
