Hi I was wondering if I can collect and output/save the messages printed in LOG panel?
Any help's appreciated. Thank u~
(I know I can click there to save as .log file. Wondering how to do this programmatically.)
You can also specify the log file as parameter to the process. In order to do so, click on the white area of the main process. Then you will see some parameters on the right which control the complete process execution. One of them is the parameter "logfile". Now all those log entries will be stored in the specified file on process execution.
Hope this helps,
Ingo
Nice. Thank you Ingo~
