Altair RISE
Nominate Yourself Now!
Read Model operator is deprecated from RapidMiner 7.2 and alternative ?
User: "phivu"
New Altair Community Member
Updated by Jocelyn
Hi RapidMiner,
I'm using RapidMiner 7.2 now (upgraded from 7.1), may I know what are the operators that have been removed from version 7.2 (e.g. Read Model, Write Model, etc.) and what are the alternative operators for those? Thank you very much for your help!
Best Regards,
Phi Vu
1 - 1 of 11
    User: "MartinLiebig"
    Accepted Answer
    There are actually not just two options, but three. But i think only Store/Retrieve fits here.
    1. Store/Retrieve
    This stores anything which runs through a connection in the repository. This means that the file is physically written to disc or the underlying SQL DB of the Rm Server.
    2. Remember/Recall
    With Remember you store the object running thorugh a wire in a "process variable". Thus the object is still in memory and not written to disc. If you don't do anything with it the data will be lost after running the process and the garbage collection things it can delete it.
    3. Publish to App/Recall from App
    This works pretty similar to Remember/Recall, but is session wide. So you can Recall App objects also from other processes within the same session.  That way you have a storage which is not deleted after the process. It is only deleted if you you close studio or delete it manually. It is sometimes a very elegant way to have an in-memory state or memory if you are doing things on server, but it also works locally. of course this is a "creative missuse of operators".
    ~Martin
