Hi!
So I was trying to use the Direct Marketing Template provided in the newest RapidMiner. I kept on encountering problems with the Naive Bays algorithim, but I thought I eventually fixed it. I ran the program and it gave me a message that said "the set up does not seem to contain any obvious errors, but you should check the log messages or activate debug mode". I proceeded to close the program without saving and open the template again. This time I changed nothing and used RapidMiner's original layout and data. Once again this message popped up. Anyone know what might be wrong and what I can do
