Hey guys,
I backuped some RapidMiner process just as a XML file, how do I reimport the code?
If I just paste the code into the XML window, nothing happens in the pocess view.
Can you help me?
Kind regards,
Matthias
Hi Matthias,
No prob. In general you can use the items "Export Process..." and "Import Process..." from the file menu to save and load process files from a disk instead of the repository. This will generate a .rmp file.
In your case, it seems that you have XML instead like the ones you can also often find in the forums. Here is how you can import those:
I think you simply forgot to press the checkmark at the end so this should do the trick.
Have a nice weekend,
Ingo
Hello Ingo,
thanks for the reply!
I thought it was some kind of "well formed XML" checkmark .
Kind regards,Matthias
Funny :smileyhappy: But also good feedback that the icon might not work as intended. We will test this in our next usability test session and see if this is a pattern of misunderstanding.
Thanks,
I also learned it the hard way :-)
I am trying to work with a colleague using Rapidminer. We each have Rapidminer Studio, but not a server. I am having a hard time with the import process/export process functions and thought it would be better to save using XML. I went to my View, Show Panel -- but I don't have an XML option, it ends at "Tree". I am using RapidMiner Studio Educational 7.5.001 Do you have any advice?
most likely your screen resolution is not high enough to show XML. If you are on tree you can hit arrow down on your keyboard twice and hit enter to get the XML view.
Best,
Martin
