"Genetic algorithm for feature selection"
User: "kersor"
New Altair Community Member
Updated by Jocelyn
Dear community
I want to use The operator Genetic algorithm optimize selection (Evolutionary) for feature selection in a data set with numeric attributes. I would like to know if it is possible how exactly this algorithm works theoretically. More particulary, features are selected independently from the accuracy of the classifier or a subset of features is selected so as not to degrade the performance of the classifier? I think is the second but i want to be sure.
The xml of my proccess is atttached.
Best Regards
Konstantinos
1 - 2 of 21
    User: "IngoRM"
    Accepted Answer
    Hi Konstantinos,
    I think my PhD might actually be a good point to read up on the feature selection part of RapidMiner.  The middle part covers both the single- as well as multi-objective evolutionary optimization approach.  I typically recommend to go with a multi-objective approach where you try to optimize for the prediction accuracy on one hand and try to minimize the number of features on the other hand.
    The link to my PhD is here: http://www-ai.cs.uni-dortmund.de/PublicPublicationFiles/mierswa_2008a.pdf
    If the Optimize Selection operator makes the selection dependent on a generic feature relevance scheme or on a specific learner depends on how you build the process.  If you put a cross-validation with a certain learner, let's say Naive Bayes, inside of the Optimize Selection operator, then the feature selection is optimized for the accuracy of this particular learner.  This process in the Sample repository delivered with RapidMiner shows how this works in general:
    //Samples/processes/04_Attributes/10_EvolutionaryFeatureSelection
    Hope that helps,
    Ingo
    User: "kersor"
    OP
    Accepted Answer
    Thank you so much for your reply, you helped me a lot.
    Best Regards
