I am new to RM an trying to explore capabilities.
When I try to specify the links to follow, the required links where not followed as expected.
I have finally removed all 'imitations' and the links are still not followed.
One conclusion was that relative URL's are not handled properly. But this proved wrong with a test on the Site http://www.formel1.de/rennergebnisse/2016/grosser-preis-von-deutschland/rennen with 'rennergebnisse
I use this simple process:
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="web:crawl_web" compatibility="7.2.000" expanded="true" height="68" name="Crawl Web (2)" width="90" x="45" y="34">
<parameter key="url" value="https://firmen.wko.at/Web/Ergebnis.aspx?StandortID=123&StandortName=Innsbruck+Land&Branche=3852&BranchenName=Industrie&CategoryID=0"/>
<list key="crawling_rules">
<parameter key="follow_link_with_matching_url" value=".*"/>
</list>
<parameter key="write_pages_into_files" value="false"/>
<parameter key="add_pages_as_attribute" value="true"/>
<parameter key="output_dir" value="C:\Users\Administrator\Documents\traRM"/>
<parameter key="extension" value="txt"/>
<parameter key="max_pages" value="5"/>
<parameter key="max_depth" value="999"/>
<parameter key="domain" value="server"/>
<parameter key="delay" value="1000"/>
<parameter key="max_threads" value="1"/>
<parameter key="max_page_size" value="99000"/>
<parameter key="user_agent" value="Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.106 Safari/537.36 OPR/38.0.2220.41"/>
<parameter key="obey_robot_exclusion" value="false"/>
<parameter key="really_ignore_exclusion" value="true"/>
<operator activated="false" class="store" compatibility="7.2.000" expanded="true" height="68" name="Store" width="90" x="514" y="34">
<parameter key="repository_entry" value="../data/WKO_Test"/>
<connect from_op="Crawl Web (2)" from_port="Example Set" to_port="result 1"/>
</process>
</process>
The result is just one page and the log shows:
Aug 4, 2016 10:51:32 AM INFO: Process //Local Repository/processes/WKO_Retrieve_Only starts
Aug 4, 2016 10:51:34 AM INFO: Storing page https://firmen.wko.at/Web/Ergebnis.aspx?StandortID=123&StandortName=Innsbruck+Land&Branche=3852&BranchenName=Industrie&CategoryID=0
Aug 4, 2016 10:51:34 AM INFO: Saving results.
Aug 4, 2016 10:51:34 AM INFO: Process //Local Repository/processes/WKO_Retrieve_Only finished successfully after 2 s
If I set the domain param from 'server' to 'web', other site-links are followed but still not those from within this site.
What I am doing wrong ?
