any idea how to create a (sub)directory directly in Dropbox?
Thanks.
Pavel
the "write dropbox" operator's parameter file can point ot non-existing folder structure, the operator automatically creates the necessary subfolders based on the path you provides.
So you can basically assume that necessary folders are created.
If you need to specifically create a subfolder, then you will need to write a dummy file in that folder
