Hi, it seems `execute R` only expect a data table as the return value.
When I return a simple real number, and it's recognized as `memory buffered file`.
(Tried to return a model, and same thing happened.)
Any help's appreciated. Thanks-
Code:
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="r_scripting:execute_r" compatibility="6.4.000" expanded="true" height="76" name="test" width="90" x="313" y="30">
<parameter key="script" value="rm_main = function(){ cat('Starting R script now ...\n') x = 0.1 x }"/>
<connect from_op="test" from_port="output 1" to_port="result 1"/>
<portSpacing port="source_input 1" spacing="90"/>
</process>
</process>
