Hi I just found there are two processes for calling R - is one of them obsolete? Thanks
Code is here - it seems to say `execute R` is for rapidminer 6.4 and `execute script (R)` is for 5.3
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="r_scripting:execute_r" compatibility="6.4.000" expanded="true" height="60" name="test" width="90" x="179" y="120">
<parameter key="script" value="rm_main = function(){ } "/>
<operator activated="true" class="r:execute_script_r" compatibility="5.3.000" expanded="true" height="60" name="Execute Script (R)" width="90" x="179" y="210">
<enumeration key="inputs"/>
<list key="results">
<parameter key="acc" value="Generic R Result"/>
<parameter key="dt" value="Data Table"/>
</list>
<portSpacing port="source_input 1" spacing="90"/>
</process>
</process>
