I have data in a SQL server table that is only able to be extracted using a stored procedure. The data in the underlying table is stored as a binary blob.
How do I do this?
Derek
You can run SQL scripts in rapidminer studio thru 'Execute SQL' operator.
Put your SQL codes that run a stored procedure in the query window.
The stored procedure may create a data table in your database and you can retrieve &load db table with 'Read database' operator.
Hi!
Microsoft SQL Server and most modern SQL databases support the Common Table Expression syntax. You can wrap your procedure call in a CTE and then access the result as a virtual table.
If your procedure call works like this:
CALL yourprocedure()
You should be able to use the following expression in a Read Database operator:
WITH dataset AS (
SELECT * FROM dataset
your simplest option may be using the "Read Database" operator and use use "call <procedurename(params)>"
For example if my procedure looks like below
To use from Rapidminer "Read database" you can modify the sql to look something like this
How do we make that 200 a parameter that can be keyed by user ? Will it prompt user for value .
The preferred solution for this is using "prepare statement" and changing the "200" in the query to a question mark ("?").
Now you have different options. The user can enter 200 directly in the Parameters window, or you can use a macro. Macros have the syntax %{macroName} and can be set in the process context, or using Set Macro or Extract Macro.
Balázs
