Altair Inspire not opening
I downloaded Inspire and believe I set it up properly. When I go to open up the app, it goes to the loading screen as if it is working and then it fails after like 5 seconds and closes without telling me why. I've tried reinstalling and a bunch of other things as well. Not sure what the problem is.
If there is no corruption in the installation file, it may be a graphics card problem;
Onboard graphics card is not supported.
For NVIDIA etc. graphics cards, please install the latest driver version.0 -
I have the same issue.
Graphics card is RTX2070 MaxQ and is up to date.There is also an integrated GPU for basic tasks on the laptop
Please help
0 -
Please help
I found a solution that worked for me. In my case, the issue was an incomplete installation, although the InstallAnywhere wizard was (sometimes) reporting a successful installation.
Issue was with Java and Windows 11 dlls. Creating a system environment variable as shown below solved the install issue, and Inspire is now working.Name: JAVA_TOOL_OPTIONS
Value: "-Dos.name=Windows 7"Hope this helps
