🎉Community Raffle - Win $25
Join and Win
Splitting one dataset to multiple operators
User: "amotley"
New Altair Community Member
Updated by Jocelyn
Is there an operator that essentially doest the opposite of the multiply operator? Instead of allowing one operator to be multiplied out to many different operators, is there one that condences multiple operators to all be able to go into the same next step???
Thanks!
1 - 4 of 41
    is the subprocess operator maybe what you search for?
    ~Martin
    User: "hughesfleming68"
    The Join operator might be another option.
    Alex
    User: "YYH"
    Depends on your user case. Can you please give us a bit more detailed goal you want to achieve?
    Some data blending operators, maybe useful for you...
    Join
    Union
    Append
    User: "JessForbesRM"
    Our Append operator may be what you are looking for.  It will allow the merging of datasets with the same number of attributes.
    http://docs.rapidminer.com/studio/operators/blending/table/joins/append.html
    There are a number of other join operators that may help too, I would recommend searching "joins" in your operator view and examine the options.  Each operator that you suggest will change the help view to the appropriate notes on the operator.
