Output sorted weight table from LibSVM linear operator
User: "hughesfleming68"
New Altair Community Member
Updated by Jocelyn
I am trying to export a file that has a sorted list of the kernel model. I can write an unsorted one with write as text but with no flexibilty. Ideally I would also like to extract the highest and lowest values.
I am assuming that this could be done by using execute script or is there another way to make the weight table more manageable?
regards,
Alex
1 - 1 of 11
    User: "land"
    Accepted Answer
    Hi Alex,
    I couldn't agree more with you that RapidMiner should add a generic "Object to Data" adapter. If the object has some tabular data inside that shouldn't be that problematic, I guess...I would vote for this feature ;)
    Greetings,
      Sebastian
