Normally, if I create an advanced chart in one example set of an object collection, I can click through each example set in the collection and the chart will still exist. Lately, however, I have one set where if I click to a different example set it deletes all the settings in the chart configuration. it makes advanced charts unusable in this form
I am using rapidminer 7.1.1 and I have not seen this behavior before. the xml is below. The first (top most) collection created by loop values works fine and correctly with advanced charts, the second one does not.
<process version="7.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.1.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="7.1.001" expanded="true" height="68" name="Read CSV" width="90" x="112" y="34">
<parameter key="csv_file" value="E:\SPC-output.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Comment"/>
<parameter key="1" value="Name"/>
</list>
<parameter key="encoding" value="windows-1252"/>
<parameter key="0" value="#_PARTNO.true.polynominal.attribute"/>
<parameter key="1" value="#_SN.true.polynominal.attribute"/>
<parameter key="2" value="calculated average spring length.true.real.attribute"/>
<parameter key="3" value="positive fract change.true.real.attribute"/>
<parameter key="4" value="negative fract change.true.real.attribute"/>
<parameter key="5" value="poslimdeg.true.real.attribute"/>
<parameter key="6" value="neglimdeg.true.real.attribute"/>
<parameter key="7" value="poslim.true.real.attribute"/>
<parameter key="8" value="neglim.true.real.attribute"/>
<parameter key="9" value="fract neg limit.true.real.attribute"/>
<parameter key="10" value="angle.true.real.attribute"/>
<parameter key="11" value="fractposlim.true.real.attribute"/>
<parameter key="12" value="att13.false.attribute_value.attribute"/>
<parameter key="13" value="actual target deflection.true.real.attribute"/>
<parameter key="14" value="spreadsheet target .true.real.attribute"/>
<parameter key="15" value="ratio.false.integer.attribute"/>
<parameter key="16" value="Corrected measured.true.real.attribute"/>
<parameter key="17" value="shift off target degrees.true.real.attribute"/>
<parameter key="18" value="fract shift.true.real.attribute"/>
<parameter key="19" value="corrfract.true.real.attribute"/>
<parameter key="20" value="att21.false.attribute_value.attribute"/>
<parameter key="21" value="att22.false.integer.attribute"/>
</list>
<operator activated="true" class="multiply" compatibility="7.1.001" expanded="true" height="166" name="Multiply" width="90" x="246" y="34"/>
<operator activated="true" class="loop_values" compatibility="7.1.001" expanded="true" height="103" name="Loop Values" width="90" x="112" y="544">
<parameter key="attribute" value="#_PARTNO"/>
<operator activated="true" class="filter_examples" compatibility="7.1.001" expanded="true" height="103" name="Filter Examples (3)" width="90" x="112" y="187">
<list key="filters_list">
<parameter key="filters_entry_key" value="#_PARTNO.equals.%{loop_value}"/>
</list>
<operator activated="true" class="multiply" compatibility="7.1.001" expanded="true" height="103" name="Multiply (2)" width="90" x="246" y="238"/>
<operator activated="true" class="aggregate" compatibility="7.1.001" expanded="true" height="82" name="Aggregate" width="90" x="45" y="493">
<parameter key="corrfract" value="average"/>
<parameter key="corrfract" value="standard_deviation"/>
<parameter key="corrfract" value="maximum"/>
<parameter key="corrfract" value="minimum"/>
<parameter key="fractposlim" value="average"/>
<parameter key="fract neg limit" value="average"/>
<parameter key="#_PARTNO" value="count"/>
<parameter key="shift off target degrees" value="average"/>
</list>
<parameter key="group_by_attributes" value="angle"/>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="493">
<parameter key="2sig" value="[standard_deviation(corrfract)]*2"/>
<parameter key="3sig" value="[standard_deviation(corrfract)]*3"/>
<parameter key="partno1" value="%{loop_value}"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="313" y="493">
<parameter key="1sigUB" value="[average(corrfract)]+[standard_deviation(corrfract)]"/>
<parameter key="1sigLB" value="[average(corrfract)]-[standard_deviation(corrfract)]"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="447" y="493">
<parameter key="1sigUBdelta" value="[average(fractposlim)]-[1sigUB]"/>
<parameter key="1siglbdelta" value="[1sigLB]-[average(fract neg limit)]"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (4)" width="90" x="45" y="595">
<parameter key="NsigUL" value="([1sigUBdelta]+[standard_deviation(corrfract)])/[standard_deviation(corrfract)]"/>
<parameter key="NsigLL" value="([1siglbdelta]+[standard_deviation(corrfract)])/[standard_deviation(corrfract)]"/>
<parameter key="NsigOffDelta" value="([NsigUL]-[NsigLL])/2"/>
<parameter key="OffsetFract" value="[NsigOffDelta]*[standard_deviation(corrfract)]"/>
</list>
<operator activated="true" class="extract_macro" compatibility="7.1.001" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="595">
<parameter key="macro" value="minval1"/>
<parameter key="macro_type" value="statistics"/>
<parameter key="statistics" value="min"/>
<parameter key="attribute_name" value="1sigUBdelta"/>
<list key="additional_macros"/>
<operator activated="true" class="extract_macro" compatibility="7.1.001" expanded="true" height="68" name="Extract Macro (2)" width="90" x="313" y="595">
<parameter key="macro" value="minval2"/>
<parameter key="attribute_name" value="1siglbdelta"/>
<operator activated="true" class="generate_macro" compatibility="7.1.001" expanded="true" height="82" name="Generate Macro" width="90" x="447" y="595">
<parameter key="minvalnet" value="min(eval(%{minval1}),eval(%{minval2}))"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (5)" width="90" x="45" y="697">
<parameter key="minvalsig" value="eval(%{minvalnet})"/>
</list>
<operator activated="true" class="numerical_to_real" compatibility="7.1.001" expanded="true" height="82" name="Numerical to Real" width="90" x="179" y="697">
<parameter key="attribute" value="minvalsig"/>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (6)" width="90" x="380" y="697">
<parameter key="minvalbyrow" value="min([1siglbdelta],[1sigUBdelta])"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (7)" width="90" x="514" y="697">
<parameter key="TEMPoffract" value="if(minvalbyrow == minvalsig,OffsetFract,-1000)"/>
</list>
<operator activated="true" class="extract_macro" compatibility="7.1.001" expanded="true" height="68" name="Extract Macro (3)" width="90" x="648" y="697">
<parameter key="macro" value="offsetvalue1"/>
<parameter key="statistics" value="max"/>
<parameter key="attribute_name" value="TEMPoffract"/>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (8)" width="90" x="45" y="799">
<parameter key="OffsetAverage" value="[average(corrfract)]+eval(%{offsetvalue1})"/>
<parameter key="OffsetNsigUL" value="([average(fractposlim)]-OffsetAverage)/[standard_deviation(corrfract)]"/>
<parameter key="OffsetNsigLL" value="([average(fract neg limit)]-OffsetAverage)/[standard_deviation(corrfract)]"/>
<parameter key="OffsetfFdeltUL" value="([average(fractposlim)]-OffsetAverage)"/>
<parameter key="OffsetFdeltLL" value="([average(fract neg limit)]-OffsetAverage)"/>
<parameter key="OffsetNsigperMiliFractLL" value="[OffsetNsigLL]/(1000*[OffsetFdeltLL])"/>
<parameter key="OffsetNsigperMiliFractUL" value="[OffsetNsigUL]/(1000*[OffsetfFdeltUL])"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (9)" width="90" x="179" y="799">
<parameter key="NsigPerMinuteOfAngleLL" value="OffsetNsigperMiliFractLL*1000/(60*angle)"/>
</list>
<connect from_port="example set" to_op="Filter Examples (3)" to_port="example set input"/>
<connect from_op="Filter Examples (3)" from_port="example set output" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_port="out 1"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/>
<connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Generate Attributes (3)" to_port="example set input"/>
<connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Generate Attributes (4)" to_port="example set input"/>
<connect from_op="Generate Attributes (4)" from_port="example set output" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/>
<connect from_op="Extract Macro (2)" from_port="example set" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_op="Generate Attributes (5)" to_port="example set input"/>
<connect from_op="Generate Attributes (5)" from_port="example set output" to_op="Numerical to Real" to_port="example set input"/>
<connect from_op="Numerical to Real" from_port="example set output" to_op="Generate Attributes (6)" to_port="example set input"/>
<connect from_op="Generate Attributes (6)" from_port="example set output" to_op="Generate Attributes (7)" to_port="example set input"/>
<connect from_op="Generate Attributes (7)" from_port="example set output" to_op="Extract Macro (3)" to_port="example set"/>
<connect from_op="Extract Macro (3)" from_port="example set" to_op="Generate Attributes (8)" to_port="example set input"/>
<connect from_op="Generate Attributes (8)" from_port="example set output" to_op="Generate Attributes (9)" to_port="example set input"/>
<connect from_op="Generate Attributes (9)" from_port="example set output" to_port="out 2"/>
<portSpacing port="sink_out 3" spacing="0"/>
</process>
<operator activated="true" class="multiply" compatibility="7.1.001" expanded="true" height="124" name="Multiply (3)" width="90" x="313" y="595"/>
<operator activated="true" class="filter_examples" compatibility="7.1.001" expanded="true" height="103" name="Filter Examples (2)" width="90" x="313" y="340">
<parameter key="filters_entry_key" value="#_PARTNO.equals.9-217688-04"/>
</list>
<operator activated="true" class="filter_examples" compatibility="7.1.001" expanded="true" height="103" name="Filter Examples" width="90" x="380" y="187">
<parameter key="filters_entry_key" value="#_PARTNO.equals.9-217588-04"/>
</list>
<connect from_op="Read CSV" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_port="result 1"/>
<connect from_op="Multiply" from_port="output 2" to_port="result 2"/>
<connect from_op="Multiply" from_port="output 3" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 4" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 5" to_op="Loop Values" to_port="example set"/>
<connect from_op="Loop Values" from_port="out 1" to_port="result 5"/>
<connect from_op="Loop Values" from_port="out 2" to_op="Multiply (3)" to_port="input"/>
<connect from_op="Multiply (3)" from_port="output 1" to_port="result 6"/>
<connect from_op="Multiply (3)" from_port="output 2" to_port="result 7"/>
<connect from_op="Multiply (3)" from_port="output 3" to_port="result 8"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_port="result 4"/>
<connect from_op="Filter Examples" from_port="example set output" to_port="result 3"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
<portSpacing port="sink_result 7" spacing="0"/>
<portSpacing port="sink_result 8" spacing="0"/>
<portSpacing port="sink_result 9" spacing="0"/>
</process>
</process>
