Technical discussions have been migrated to the Siemens Support Center as Knowledge Base (KB) articles; please note that this content is no longer maintained and may be outdated, so for the latest information, log in to the Siemens Support Center, search online, or contact our support team.
While replying or asking question if you need to share RapidMiner process, then you should export the process using File(Menu) >> Export RapidMiner process.
That saves a file with .rmp extension
Then you can upload the file instead of pasting XML
