I am trying to run the rapidminer-server-installer script and go through the setup wizard to plug in my DB information. When I attempt to run the script (linux) it errors out:
[root@XXXXXXXXX bin]# ./rapidminer-server-installer
No protocol specified
Exception in thread "main" java.lang.InternalError: Can't connect to X11 window server using 'XXXXXXXXXX:0.0' as the value of the DISPLAY variable.
at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
at sun.awt.X11GraphicsEnvironment.access$200(Unknown Source)
at sun.awt.X11GraphicsEnvironment$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.awt.X11GraphicsEnvironment.<clinit>(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at java.awt.GraphicsEnvironment.createGE(Unknown Source)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(Unknown Source)
at sun.awt.X11.XToolkit.<clinit>(Unknown Source)
at java.awt.Toolkit$2.run(Unknown Source)
at java.awt.Toolkit.getDefaultToolkit(Unknown Source)
at javax.swing.ImageIcon.<init>(Unknown Source)
at com.rapidminer.server.installer.gui.tools.SwingTools.createImage(SwingTools.java:195)
at com.rapidminer.gui.look.Colors.<init>(Colors.java:238)
at com.rapidminer.gui.look.RapidLookAndFeel.<clinit>(RapidLookAndFeel.java:37)
at com.rapidminer.server.installer.Starter.main(Starter.java:36)
FYI - Before running the script I tried to set the display per my machines IP address. Could there be some network related issue blocking it or am I missing something ?
Thank you,
Danny
