What do you do if you get this error?
Your license does not include motor control design suite
If you are using the Altair license then go to license setup from "options"
Then check all the boxes:
You will need to restart.
Note: you will now be using 20 units.
If you are using the Altair license then go to license setup from "options" Then check all the boxes: You will need to restart. Note: you will now be using 20 units.
Dear Mr.Dunford
Thank you for your repry.
I was able to do it by following the procedure you taught me.
Thank you so much.
Regards,Nakagawa.
