seconds,DateTime,att1,Longitude,Latitude33.979,2015-05-07 19:04:56 252,1.296,7.401099,51.482471
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="6.4.000" expanded="true" height="60" name="Read CSV" width="90" x="313" y="30"> <parameter key="csv_file" value="/home/test/test.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="UTF-8"/> <list key="data_set_meta_data_information"> <parameter key="0" value="seconds.true.real.attribute"/> <parameter key="1" value="DateTime.true.polynominal.attribute"/> <parameter key="2" value="att1.true.real.attribute"/> <parameter key="3" value="Longitude.true.real.attribute"/> <parameter key="4" value="Latitude.true.real.attribute"/> </list> </operator> <operator activated="true" breakpoints="before,after" class="nominal_to_date" compatibility="6.4.000" expanded="true" height="76" name="Nominal to Date" width="90" x="581" y="30"> <parameter key="attribute_name" value="DateTime"/> <parameter key="date_type" value="date_time"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss SSS"/> <parameter key="time_zone" value="Europe/Berlin"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="715" y="30"> <list key="function_descriptions"> <parameter key="datetimemilliseconds" value="date_get(DateTime,DATE_UNIT_MILLISECOND)"/> </list> </operator> <connect from_op="Read CSV" from_port="output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Hello, I have the same "problem". Did anyone find a solution?
I'm working with higher frequent sensor data (milliseceonds) and want to keep it visual in the date_time attribute (even if the information it is not lost). Looking forward to hearing from you.
I tried the old example file from the original post, but could not replicate the problem in RM 7.5, as milliseconds are displayed correctly after using the import wizard. Could you provide one line of your data with a timestamp?
Alternatively, you could try the "Format Numbers" operator with format type "Pattern", but you may need to change the datatype of your timestamp first.
Thanks for the fast reply.
One example timestamp is "2017-07-22T09:10:11.1230000Z". With the Import Wizard / Nomial to Date (RM7.5) no suitable date format works. If I define "yyyy-MM-dd'T'HH:mm:ss.SSS" it looks like "Jul 22, 2017 09:10:11 AM CEST", but many of the new timestamps are calculated wrong.
It is important to work with the date_time format, because I need it for filtering and labeling the data in an following step.
Ok, I am starting to believe that this could be indeed a bug (or a feature). The format is just not displayed in the corresponding date_time pattern, once the value is converted to type date_time. However, all information is available and you can actually apply filters that take the micro information (e.g. ms) that is not displayed into account.
Rapidminer apparently always shows the format you describe when data is of the date_time type. I also tried the "Generate Attribute" operator and made some re-formatting (text transformation and conversion functions) prior to type conversion, as I thought that the 7 digits for the milliseconds could cause the issue. However, they don't. If you need it solely for the "visibility", one not very elegant way would be to duplicate the attribute. Then you can use the date_type version for your processing needs and convert the duplicate to nominal, which then shows the format you want.
With only the one example, I could not verify that the "Nominal to Date" operator is calculating wrong timestamps, which would be surprising. However, I believe this is something that can be solved easily. Maybe you want to take a look at the conversion functions in the "Generate Attribute" operator. I am working a lot with high precision timestamps and never encountered "wrong" timestamps, and if so it was always human error.
Indeed,
The format "Jul 22, 2017 9:10:11 AM CEST" is the RapidMiner visual representation of the value type date_time.
Internally those values are kept as milliseconds which can be used for filtering. So if you want to see the milliseconds within your date format you need to convert your date attribute to Nominal.
Regarding the point of wrongly calculated timestamps:
Please have a look at the Parameters "time zone" and "locale" of the Operator Nominal to Date. I assume that those help you.
Just as a sidenote:
Generate Attributes has the built-in function date_millis(<your date attribute>) to display your date attribute in milliseconds starting from 01/01/1970.
Best,
Edin
