The document "How to Extend RapidMiner 5" describes how to create Configurables, for example to store Connections to certain servers (Chapter 8 ). I try to do so for a RapidMiner Studio, and as it turns out, many of the code is applicable for this version. However, I ran into some difficulties.
I have for my Operator overridden the getParameterTypes function:
public List<ParameterType> getParameterTypes() {
List<ParameterType> types = super.getParameterTypes();
types.add(new ParameterTypeConfigurable(PARAMETER_CONFIG, "Choose a Connection", "Config"));
types.add(new ParameterTypeInt(PARAMETER_TASKID, "The Task that needs to be executed", 1, Integer.MAX_VALUE, false));
return types;
Hence, I can see both the integer and configurable parameter fields.
Now, if I want to access the integer parameter, I can easily access it in the doWork function:
getParameterAsInt(PARAMETER_TASKID);
I would assume there is a similar way to obtain the Configurable? Yet, I can't find it, and it is not documented in the manual. Many thanks for helping out.
