I got myself community RM5 from sourceforge, but when I'm trying to run it, the ui is a mess:
http://i.imgur.com/9oN7Tgf.pngI've tried to run by clicking [tt]lib/rapidminer.jar[/tt] and [tt]lib/launcher.jar[/tt], by running through [tt]java -jar rapidminer.jar[/tt], by running with [tt]scripts./RapidMinerGUI[/tt]. Nothing helped.
I should have required java:
$ java -version
java version "1.7.0_79"
Java(TM) SE Runtime Environment (build 1.7.0_79-b15)
Java HotSpot(TM) 64-Bit Server VM (build 24.79-b02, mixed mode)
running on linux:
$ uname -roms
Linux 4.1.4-1-ARCH x86_64 GNU/Linux
this is stdout when running the RapidMinerGUI script:
$ ./RapidMinerGUI
RAPIDMINER_HOME is not set. Trying the directory '.'...
Number of cores: 2
Number of GC Threads: 1
No maximum Java memory defined, using 1024 Mb...
Starting RapidMiner from '.', using classes from './lib/rapidminer.jar'...
Java version: 17
Starting with G1 garbage collector
Starting in multi-core mode
Aug 14, 2015 4:58:45 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is '.'.
Aug 14, 2015 4:58:46 PM com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform ANY
Aug 14, 2015 4:58:46 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Aug 14, 2015 4:58:46 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Aug 14, 2015 4:58:47 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
Aug 14, 2015 4:58:50 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of expression parser registered successfully
Aug 14, 2015 4:58:52 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Aug 14, 2015 4:58:54 PM com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 443; number of registered operator descriptions: 444; number of replacements: 403
Aug 14, 2015 4:58:54 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Aug 14, 2015 4:58:54 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
[Fatal Error] :1:1: Premature end of file.
Any help would be appreciated, thanks
