<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Iris" width="90" x="45" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="discretize_by_frequency" compatibility="5.3.013" expanded="true" height="94" name="Discretize by Frequency" width="90" x="179" y="120"> <parameter key="number_of_bins" value="5"/> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.3.013" expanded="true" height="94" name="Nominal to Binominal" width="90" x="313" y="120"> <parameter key="transform_binominal" value="true"/> <parameter key="use_underscore_in_name" value="true"/> </operator> <operator activated="true" class="fp_growth" compatibility="5.3.013" expanded="true" height="76" name="FPGrowth" width="90" x="447" y="120"> <parameter key="find_min_number_of_itemsets" value="false"/> <parameter key="min_number_of_itemsets" value="1"/> <parameter key="min_support" value="0.1"/> <parameter key="must_contain" value=""a1*|a2*""/> </operator> <operator activated="true" class="create_association_rules" compatibility="5.3.013" expanded="true" height="76" name="Create Association Rules" width="90" x="581" y="120"/> <connect from_op="Iris" from_port="output" to_op="Discretize by Frequency" to_port="example set input"/> <connect from_op="Discretize by Frequency" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="FPGrowth" to_port="example set"/> <connect from_op="FPGrowth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/> <connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="108"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Thanks a lot
