<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Ripley-Set" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Ripley-Set"/> </operator> <operator activated="true" class="publish_to_app" compatibility="6.4.000" expanded="true" height="60" name="Publish to App" width="90" x="179" y="75"> <parameter key="name" value="breakpoint"/> </operator> <operator activated="true" class="logistic_regression" compatibility="6.4.000" expanded="true" height="94" name="Logistic Regression" width="90" x="179" y="165"/> <operator activated="true" class="publish_to_app" compatibility="6.4.000" expanded="true" height="60" name="Publish to App (2)" width="90" x="313" y="165"> <parameter key="name" value="breakpoint"/> </operator> <operator activated="true" class="apply_model" compatibility="6.4.000" expanded="true" height="76" name="Apply Model" width="90" x="447" y="165"> <list key="application_parameters"/> <description align="center" color="transparent" colored="false" width="126">Oh no! An Error! How to get my model back!</description> </operator> <connect from_op="Retrieve Ripley-Set" from_port="output" to_op="Publish to App" to_port="store"/> <connect from_op="Publish to App" from_port="stored" to_op="Logistic Regression" to_port="training set"/> <connect from_op="Logistic Regression" from_port="model" to_op="Publish to App (2)" to_port="store"/> <connect from_op="Publish to App (2)" from_port="stored" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
welcome @nathanjame92 !!
Scott
