My computer has an accelerator in FEKO. I want to speed up FEKO solver using the accelerator. It says to use --use gpu in the CADFEKO command line. I don't know how to access the command line. How do I do this ?
You don't need the command line. You can enable from the CADFEKO or POSTFEKO:
Note that the GPU is mostly used for the FDTD (time domain) solver.
You don't need the command line. You can enable from the CADFEKO or POSTFEKO: Note that the GPU is mostly used for the FDTD (time domain) solver.
To do this from the command line only, open a Feko terminal (click below on the right)
and then run for example:
runfeko mymodelname --feko-options --use-gpu
